迅雷点开是灰色的?
有关迅雷的问题反馈及使用讨论
xuesong0532
迅雷点开是灰色的?
帖子 xuesong0532 »
应用商店新上了迅雷,安装点开后,界面是灰色的,有点儿类似要弹出登录窗口或广告似的,就是看不见。
F4-221 X86 最新版本OS
Frank
Re: 迅雷点开是灰色的?
帖子 Frank »
我也是一样,不能用
F4-421 8G MAPL0303V17 TOS 7
Re: 迅雷点开是灰色的?
帖子 147659159 »
我的也一样
NAS型号:F5-421
TOS版本:4.2.32
pan-cli.log里面出了下面这些
2022-05-28T14:27:19.080130756+09:00 INFO  platformdetect/detect.go:211 detect lexar error:env ea94acab567b9cc724e943be3e4ac5c5 not exist
2022-05-28T14:27:19.080230841+09:00 INFO  platformdetect/detect.go:211 detect docker error:stat /.dockerenv: no such file or directory
2022-05-28T14:27:19.080281855+09:00 INFO  platformdetect/detect.go:211 detect zspace error:env a68b3d890b860d0165a8f6f66acc6d45 not exist
2022-05-28T14:27:19.080331619+09:00 INFO  platformdetect/detect.go:211 detect synology error:stat /etc/synoinfo.conf: no such file or directory
2022-05-28T14:27:19.0803843+09:00 INFO  platformdetect/detect.go:211 detect hiksemi error:env 985cd73ad6cd84581921672853ef6c5e not exist
2022-05-28T14:27:19.080430437+09:00 INFO  platformdetect/detect.go:211 detect ugreen error:env c2fa07c50ad61b50a634a9c25bc40530 not exist
2022-05-28T14:27:19.080476324+09:00 INFO  platformdetect/detect.go:211 detect qnap error:env 71b00dc127a6a78de61e59fd9628efae not exist
2022-05-28T14:27:19.080583799+09:00 INFO  platformdetect/detect.go:211 detect terramaster error:a69c84a628c199bc14f166b95b055c4a format error
2022-05-28T14:27:19.080632849+09:00 INFO  platformdetect/detect.go:211 detect lenovo error:env 4c591aaded5306eb667b896eed02e6e6 not exist
2022-05-28T14:27:19.080678996+09:00 INFO  platformdetect/detect.go:211 detect ubuntu error:env bc519ec4f100ddff5670990978d0e76f not exist
2022-05-28T14:27:19.080725084+09:00 INFO  platformdetect/detect.go:211 detect xcloud error:env 6c9023c15749f4c07f09e8e6a0f78b12 not exist
2022-05-28T14:27:19.080773203+09:00 INFO  platformdetect/detect.go:211 detect macos error:env 973a737d292d1a499a47894e4aa0840d not exist
2022-05-28T14:27:19.080857086+09:00 INFO  platformdetect/detect.go:211 detect raspbian error:env 5a286a70691e0be2ea2815ff72fbec08 not exist
2022-05-28T14:27:19.08090648+09:00 INFO  platformdetect/detect.go:211 detect linux error:env afca85945af91c370e2869d3f30ae500 not exist
2022-05-28T14:27:19.08095098+09:00 INFO  platformdetect/detect.go:30 platform not suport:
2022-05-28T14:27:19.080998618+09:00 INFO  platformdetect/detect.go:33 detect platform:   nasid: labels: []
2022-05-28T14:27:19.081954952+09:00 INFO  service/logger.go:59 [latency=&comment=&clientIP=192.168.0.5&time=2022-05-28T14:27:19.08191052+09:00&method=POST&status=200&request=/device/info/watch]http
TMnorah
Re: 迅雷点开是灰色的?
帖子 TMnorah »
感谢您的反馈,我们会对此问题进行验证。
Re: 迅雷点开是灰色的?
你好,针对你出现的这个现象:
1.尝试切换为Google Chrome浏览器。
2.尝试清除浏览器缓存。
3.请检查一下浏览器的模式,是隐私模式或者无痕模式呢,这两个模式是不行的。
4.请将TOS系统升级到TOS4.2.39。
5.请检查TOS系统时间与电脑的系统时间是否相差较大,如果时间差别较大(3分钟以上),二维码会无法刷新出来。
6.尝试将铁威马设备的DNS改为自动获取。
xuesong0532
Re: 迅雷点开是灰色的?
帖子 xuesong0532 »
TMjack 写了: 2022年 5月 29日 星期天 9:01 am 你好,针对你出现的这个现象:
1.你可以切换为Google Chrome浏览器尝试一下,或者清除一下浏览器缓存。
2.你可以尝试将TOS系统升级到TOS4.2.39试试。
3.这个页面要求登录讯雷帐号,请尝试登录一下
1.一直用chrome,版本102,后来又试了edge,苹果的Safari,状况相同
2.TOS版本就是4.2.39
3.界面什么都没有,咋登录?看网上搜到的视频,界面应该弹出带有二维码的登录界面,但是我们这几位都是灰色的,什么都看不到。按ESC这个灰色界面消失,但是左侧的任何选项,点了之后,依然变灰色。
Re: 迅雷点开是灰色的?
是否方便远程查看一下呢?如果可以,请发送邮件给我们技术支持团队(support_cn(at)terra-master.com (请自行用“@”替换“at”))。
Re: 迅雷点开是灰色的?
你好,请尝试以下对策:
2.尝试清除浏览器缓存。
xuesong0532
Re: 迅雷点开是灰色的?
帖子 xuesong0532 »
TMRyan 写了: 2022年 5月 29日 星期天 3:40 pm 是否方便远程查看一下呢?如果可以,请发送邮件给我们技术支持团队(support_cn(at)terra-master.com (请自行用“@”替换“at”))。
可以的。你如何远程?NAS我没放公网外联。
Re: 迅雷点开是灰色的?
那应该是您的TNAS没有连外网,系统无法向迅雷发送登录请求,导致不会出现登录页面,使用迅雷是需要有外网的。
如果有网的情况可尝试以下方法:
1、将设备名改成 TNAS- 开头的名字,后续版本的应用会修复此问题。
2、尝试切换为Google Chrome浏览器。
3、尝试清除浏览器缓存。
4、请检查一下浏览器的模式,是隐私模式或者无痕模式呢,这两个模式是不行的。
5、请将TOS系统升级到TOS4.2.39。
6、请检查TOS系统时间与电脑的系统时间是否相差较大,如果时间差别较大(3分钟以上),二维码会无法刷新出来。
7、尝试将铁威马设备的DNS改为自动获取。
回到 “迅雷”
