需要运行后台任务但又不能一直开着终端窗口,于是想到了screen。
但是铁威马里面没有这个程序。于是跑到entware找到了这个程序
http://bin.entware.net/x64-k3.2/screen_ ... 64-3.2.ipk
下载下来之后用7zip解包,找到可执行文件screen。
把这个可执行文件放到cp screen /usr/bin/screen下面。
然后设置可执行权限。chmod 777 /usr/bin/screen
当然此时是不能运行的,会报错,因为没有动态链接库的正确路径。
我查看了screen的动态链接库路径是/opt/lib/ld-linux-x86-64.so.2,而铁威马linux系统里面,该文件位于/lib/ld-linux-x86-64.so.2,
mkdir -p /opt/lib/
ln -s /lib/ld-linux-x86-64.so.2 /opt/lib/ld-linux-x86-64.so.2
./screen
./screen: error while loading shared libraries: libncursesw.so.6: cannot open shared object file: No such file or directory
建立连接之后再次运行报错。
继续搞。
我之前安装了docker,所以有这个库文件。
ln -s /Volume1/@apps/DockerEngine/DockerData/overlay2/f39f5c4c5e32fe3467d25173e5f31d8481d53755af81904dcd11be4d8b5bc3df/merged/lib/x86_64-linux-gnu/libncursesw.so.6 /usr/lib/libncursesw.so.6
继续报错。
./screen
./screen: error while loading shared libraries: libtinfo.so.6: cannot open shared object file: No such file or directory
继续干。
ln -s /Volume1/@apps/DockerEngine/DockerData/overlay2/f39f5c4c5e32fe3467d25173e5f31d8481d53755af81904dcd11be4d8b5bc3df/merged/lib/x86_64-linux-gnu/libtinfo.so.6 /usr/lib/libtinfo.so.6
运行。
./screen
Cannot make directory '/opt/tmp/screens': No such file or directory
呦呦呦报错了。。。
因为 screen 需要在该路径下创建一个目录来存放会话信息,但系统中这个路径不存在。
mkdir -p /opt/tmp/screens
chmod 777 /opt/tmp/screens
成功运行!
GNU Screen version 4.09.01 (GNU) 20-Aug-23
Copyright (c) 2018-2023 Alexander Naumov, Amadeusz Slawinski
Copyright (c) 2015-2017 Juergen Weigert, Alexander Naumov, Amadeusz Slawinski
Copyright (c) 2010-2014 Juergen Weigert, Sadrul Habib Chowdhury
Copyright (c) 2008-2009 Juergen Weigert, Michael Schroeder, Micah Cowan, Sadrul Habib Chowdhury
Copyright (c) 1993-2007 Juergen Weigert, Michael Schroeder
Copyright (c) 1987 Oliver Laumann
This program is free software; you can redistribute it and/or modify it under the terms of the GNU General Public License as published by the Free
Software Foundation; either version 3, or (at your option) any later version.
This program is distributed in the hope that it will be useful, but WITHOUT ANY WARRANTY; without even the implied warranty of MERCHANTABILITY or
FITNESS FOR A PARTICULAR PURPOSE. See the GNU General Public License for more details.
You should have received a copy of the GNU General Public License along with this program (see the file COPYING); if not, see
https://www.gnu.org/licenses/, or contact Free Software Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston, MA 02111-1301 USA.
Send bugreports, fixes, enhancements, t-shirts, money, beer & pizza to screen-devel@gnu.org
Capabilities:
+copy +remote-detach +power-detach +multi-attach +multi-user +font +color-256 +utf8 -rxvt -builtin-telnet
记录一下,防止以后再用又要查资料比较麻烦。
F2-220安装screen程序
- maomaowuxian
Re: F2-220安装screen程序
您好,请问您的F2-220产品TOS系统版本是哪个呢?我们内部验证一下。
- maomaowuxian
- maomaowuxian
您好,关于TOS 5.0.176版本确认其完全适配F2-220机种。通常情况下,该版本的硬盘指示灯与网络指示灯应能正常显示,且系统能准确读取CPU温度及风扇转速等关键信息。
针对你反馈的现象,可能是由于某个必要的系统程序或服务未能成功启动所致。为解决此问题,我们建议您首先参照提供的链接中的详细指导进行操作,该指南将帮助您排查并恢复相关程序的正常运行。viewtopic.php?t=4265
若执行上述步骤后问题依旧存在,请联系我们的官方客服团队,我们将安排远程技术支持服务,确保您的问题得到及时解决,感谢您的理解与配合。
