虚拟机提示‘Error Fetching http headers’
虚拟机讨论区
fineconey
帖子 fineconey »
如图,莫名其妙的就打不开了
不知道是不是我开了ssd缓存的原因
现在不好解决。
什么原因造成的,能不能彻底删除虚拟机,重新安装。(卸载了重装没有解决)
SoapFault Object
[message:protected] => Error Fetching http headers
[string:Exception:private] =>
[code:protected] => 0
[file:protected] => /Volume1/@apps/virtualbox/webui/endpoints/lib/vboxServiceWrappers.php
[line:protected] => 9889
[trace:Exception:private] => Array
[0] => Array
[function] => __doRequest
[class] => SoapClient
[type] => ->
[args] => Array
[0] => <?xml version="1.0" encoding="UTF-8"?>
<SOAP-ENV:Envelope xmlns:SOAP-ENV="http://schemas.xmlsoap.org/soap/envelope/" xmlns:ns1="http://www.virtualbox.org/"><SOAP-ENV:B ... V:Envelope>
[1] => http://127.0.0.1:18083/
[2] =>
[3] => 1
[4] => 0
[1] => Array
[file] => /Volume1/@apps/virtualbox/webui/endpoints/lib/vboxServiceWrappers.php
[line] => 9889
[function] => __soapCall
[type] => ->
[args] => Array
[0] => IMedium_refreshState
[1] => Array
[0] => Array
[_this] => e69e193f7b8a01e6-0000000000000002
[2] => Array
[file] => /Volume1/@apps/virtualbox/webui/endpoints/lib/vboxconnector.php
[line] => 5501
[function] => refreshState
[class] => IMedium
[type] => ->
[args] => Array
[3] => Array
[line] => 4139
[function] => _mediumGetDetails
[class] => vboxconnector
[type] => ->
[args] => Array
[0] => IMedium Object
[connection:protected] => SoapClient Object
[location] => http://127.0.0.1:18083/
[_features] => 5
[_connection_timeout] => 20
[_stream_context] => Resource id #6
[_soap_version] => 1
[sdl] => Resource id #7
[httpurl] => Resource id #21
[__soap_fault] => SoapFault Object
*RECURSION*
[handle:protected] => e69e193f7b8a01e6-0000000000000002
[4] => Array
[line] => 951
[function] => remote_vboxGetMedia
[type] => ->
[args] => Array
[0] =>
[5] => Array
[file] => /Volume1/@apps/virtualbox/webui/endpoints/api.php
[line] => 316
[function] => __call
[type] => ->
[args] => Array
[0] => vboxGetMedia
[1] => Array
[0] =>
[1] => Array
[0] => Array
[data] => Array
[responseData] => Array
[errors] => Array
[persist] => Array
[messages] => Array
[previous:Exception:private] =>
[faultstring] => Error Fetching http headers
[faultcode] => HTTP
Re: 虚拟机提示‘Error Fetching http headers’
fineconey 写了: 2024年 5月 15日 星期三 1:44 pm
可以试试卸载时勾选删除配置文件的方式,
回到 “虚拟机”
