更新之后openwrt虚拟机无法启动
虚拟机讨论区
lauchinghz
更新之后openwrt虚拟机无法启动
帖子 lauchinghz »
Exception Object
[message:protected] => The virtual machine 'openwrt-08.08.2023' has terminated unexpectedly during startup with exit code 1 (0x1)
[string:Exception:private] =>
[code:protected] => 0
[file:protected] => /Volume1/@apps/virtualbox/webui/endpoints/lib/vboxconnector.php
[line:protected] => 2443
[trace:Exception:private] => Array
[0] => Array
[file] => /Volume1/@apps/virtualbox/webui/endpoints/lib/vboxconnector.php
[line] => 951
[function] => remote_progressGet
[class] => vboxconnector
[type] => ->
[args] => Array
[0] => Array
[progress] => cd20256173dbc29b-0000000000000004
[1] => Array
[file] => /Volume1/@apps/virtualbox/webui/endpoints/api.php
[line] => 316
[function] => __call
[type] => ->
[args] => Array
[0] => progressGet
[1] => Array
[0] => Array
[1] => Array
[0] => Array
[data] => Array
[responseData] => Array
[info] => Array
[completed] => 1
[canceled] =>
[description] => Starting VM
[operationDescription] => Creating process for virtual machine "openwrt-08.08.2023" (headless)
[timeRemaining] => Array
[timeElapsed] => Array
[days] => 19609
[hours] => 1
[minutes] => 53
[seconds] => 10
[percent] => 0
[success] => 1
[key] => 53474945cfd7ac0bf8114767c209c2a6
[errors] => Array
[persist] => Array
[messages] => Array
[previous:Exception:private] =>
jswh1969
Re: 更新之后openwrt虚拟机无法启动
帖子 jswh1969 »
跟我一样
Missings
帖子 Missings »
我虚拟机能启动,虚拟机里面的任务不启动
TMeric
帖子 TMeric »
Missings 写了: 2025年 6月 15日 星期天 5:58 pm 我虚拟机能启动,虚拟机里面的任务不启动
请问您的VirtualBox的版本是多少?TOS的版本是多少?可以具体描述一下您的问题吗?如果有一些截图就更好了。
Missings
帖子 Missings »
系统重启后NAS 的虚拟机需要自动启动。
系统 6.0.694-00165
Virtual Box 7.0.20 (163906)
wifisky
帖子 wifisky »
更新VBOX后,可能安装的虚拟机系统标识ID被改变了,做过脚本启动用标识ID启动的,建议用虚拟机名称脚本启动,这样不会因为虚拟机系统标识ID改变而影响脚本启动虚拟机~
NAS发烧友
回到 “虚拟机”
