F4-221 TOS 4.1.18 -> TOS 4.1.21
/var/log/crond.log 文件中有如下写失败信息,查看没有cronstamps这个目录,手工创建一个cronstamps目录,下次重启的时候又没了.
这个日志文件每分钟写一行[Wed Jun 3 22:22:01 CST 2020] exec /var/nas/everyminuteexec
想给每分钟写一次这个去掉,改/var/nas/everyminuteexec,在echo前面加个#号注释掉,重开机又出来了.
#!/bin/bash
#fmt as $1:date $2:command $3....
echo [`date`] exec $0 >> /var/log/crond.log
Jun 3 22:18:26 luckyman crond: unable to write timestamp to /var/spool/cron/cronstamps/root.sys-hourly (user root job sys-hourly)
Jun 3 22:18:26 luckyman crond: no timestamp found (user root job sys-daily)
Jun 3 22:18:26 luckyman crond: unable to write timestamp to /var/spool/cron/cronstamps/root.sys-daily (user root job sys-daily)
Jun 3 22:18:26 luckyman crond: no timestamp found (user root job sys-weekly)
Jun 3 22:18:26 luckyman crond: unable to write timestamp to /var/spool/cron/cronstamps/root.sys-weekly (user root job sys-weekly)
Jun 3 22:18:26 luckyman crond: no timestamp found (user root job sys-monthly)
Jun 3 22:18:26 luckyman crond: unable to write timestamp to /var/spool/cron/cronstamps/root.sys-monthly (user root job sys-monthly)
请看一下这个LOG是怎么回事
Re: 请看一下这个LOG是怎么回事
你的这个问题,我们已反馈给研发的同事。
