升级到5以后rsync备份无法使用
retopit
升级到5以后rsync备份无法使用
帖子 retopit »
系统版本5.0.128,设备型号F4-421
rsync服务器是ubuntu 22.04 rsync 版本3.2.3
在备份界面,rsync设置基本参数后,点击测试,直接弹出 操作失败,查看服务器rsync的日志显示
2022/07/06 02:14:08 [28716] connect from retopnas (10.1.50.23)
2022/07/06 02:14:08 [28716] module-list request from retopnas (10.1.50.23)
2022/07/06 02:20:01 [28737] connect from retopnas (10.1.50.23)
2022/07/06 02:20:01 [28737] module-list request from retopnas (10.1.50.23)
说明TOS已经和rsync服务器通信,但是却没有下文。
为确保rsync服务器正常,在Windows端使用cywin进行测试连接,结果正常
rsync retopit@10.1.50.19::rsync
password:
drwxr-xr-x            6 2022/07/04  17:11:37   .
再看rsync服务器日志
2022/07/06 01:01:09 [28665] rsyncd version 3.2.3 starting, listening on port 873
2022/07/06 02:12:58 [28711] name lookup failed for 10.1.50.246: Name or service not known
2022/07/06 02:12:58 [28711] connect from UNKNOWN (10.1.50.246)
2022/07/06 02:12:58 [28711] rsync allowed access on module rsync from UNKNOWN (10.1.50.246)
2022/07/06 02:13:10 [28711] rsync on rsync/ from retopit@UNKNOWN (10.1.50.246)
2022/07/06 02:13:10 [28711] building file list
2022/07/06 02:13:10 [28711] sent 64 bytes  received 29 bytes  total size 0
日志显示成功连接rsync服务器,说明rysnc服务器没问题
从日志看,TOS在和rsync通信时,进行了module-list 的请求,然后没有结果了,不知道是请求错误??但是rsync的配置文件中 专门写了list =yes
# GLOBAL OPTIONS
max connections = 10
log file = /var/log/rsync.log
pid file=/var/run/rsyncd.pid
syslog facility=daemon
# MODULE OPTIONS
[rsync]
comment = public archive
path = /home/rsync
use chroot = no
lock file = /var/lock/rsyncd
read only = no
list = yes
uid = retopit
gid = retopit
auth users = retopit
secrets file = /etc/rsyncd.secrets
strict modes = yes
ignore errors = yes
ignore nonreadable = yes
transfer logging = yes
timeout = 600
refuse options = checksum dry-run
所以还是请铁威马的大哥们看看是什么原因导致,因为我的设备买回来时,用TOS4是没任何问题的,rsync服务器没动过。备份了两个月,都正常。
Re: 升级到5以后rsync备份无法使用
已同时在论坛上和技术支持邮箱里收到了您反馈的情况,我们将在分析和验证后回复您,必要的时候,可能需要远程排查,不知道您是否同意?
