VirtualBox启动不了
VirtualBox启动不了
应用中心提示VirtualBox有更新,更新到99%系统突然死机,页面空白,重启机器后,VirtualBox显示未启用,点启用启动不了,如果卸载重装是不是我虚拟机原来的设置都没有了??
Re: VirtualBox启动不了
忍不住还是卸载重装了,卸载时选择保留配置文件,启动后左侧安装的homeassistant都在,但点击镜像启动时弹出提示The virtual machine 'home-assistant2' has terminated unexpectedly during startup with exit code 1 (0x1)
明细显示:
Exception Object
[message:protected] => The virtual machine 'home-assistant2' has terminated unexpectedly during startup with exit code 1 (0x1)
[string:Exception:private] =>
[code:protected] => 0
[file:protected] => /Volume1/@apps/virtualbox/webui/endpoints/lib/vboxconnector.php
[line:protected] => 2443
[trace:Exception:private] => Array
[0] => Array
[file] => /Volume1/@apps/virtualbox/webui/endpoints/lib/vboxconnector.php
[line] => 951
[function] => remote_progressGet
[class] => vboxconnector
[type] => ->
[args] => Array
[0] => Array
[progress] => cd058a4db9caee40-0000000000000004
[1] => Array
[file] => /Volume1/@apps/virtualbox/webui/endpoints/api.php
[line] => 316
[function] => __call
[type] => ->
[args] => Array
[0] => progressGet
[1] => Array
[0] => Array
[1] => Array
[0] => Array
[data] => Array
[responseData] => Array
[info] => Array
[completed] => 1
[canceled] =>
[description] => Starting VM
[operationDescription] => Creating process for virtual machine "home-assistant2" (headless)
[timeRemaining] => Array
[timeElapsed] => Array
[days] => 19608
[hours] => 14
[minutes] => 21
[seconds] => 18
[percent] => 0
[success] => 1
[key] => 53474945cfd7ac0bf8114767c209c2a6
[errors] => Array
[persist] => Array
[messages] => Array
[previous:Exception:private] =>
明细显示:
Exception Object
[0] => Array
[line] => 951
[type] => ->
[args] => Array
[0] => Array
[1] => Array
[line] => 316
[type] => ->
[args] => Array
[0] => progressGet
[1] => Array
[0] => Array
[1] => Array
[0] => Array
[data] => Array
[info] => Array
[completed] => 1
[canceled] =>
[days] => 19608
[hours] => 14
[minutes] => 21
[seconds] => 18
[percent] => 0
[success] => 1
[errors] => Array
[persist] => Array
[messages] => Array
Re: VirtualBox启动不了
升级5.1.67,再次重新安装VirtualBox,启动虚拟机又有新的错误提示:UUID {00000000-0000-0000-0000-000000000000} of the medium '/Volume1/ha/haos_ova-10.3.vmdk' does not match the value {0e34e503-3cc8-46b3-ba92-07e44016409b} stored in the media registry ('/home/xxx/.config/VirtualBox/VirtualBox.xml')
明细如下:
Exception Object
[message:protected] => UUID {00000000-0000-0000-0000-000000000000} of the medium '/Volume1/ha/haos_ova-10.3.vmdk' does not match the value {0e34e503-3cc8-46b3-ba92-07e44016409b} stored in the media registry ('/home/xxx/.config/VirtualBox/VirtualBox.xml')
[0] => Array
[line] => 951
[type] => ->
[args] => Array
[0] => Array
[progress] => e64d22d9f59bfb5e-0000000000000004
明细如下:
Exception Object
[0] => Array
[line] => 951
[type] => ->
[args] => Array
[0] => Array
Re: VirtualBox启动不了
{L_BUTTON_AT}jswh1969
可以试试重启下应用,在应用中心先把VirtualBox停用再启用。
- lauchinghz
Re: VirtualBox启动不了
- lauchinghz
Re: VirtualBox启动不了
{L_BUTTON_AT}lauchinghz
你的TOS是什么版本?更新的时候是否有将VirtualBox中的系统停止?
