更新包下载链接:https://download3.terra-master.com/TOS% ... 291528.bz2
TOS 7.0.0777 正式版本 (X86) 更新通知
Re: TOS 7.0.0777 正式版本 (X86) 更新通知
该问题已经在TOS 7.0.0777版本并未合并,请等待后续版本更新。
目前没有提供TOS 7安装包,需要从TOS 6.0.794升级到TOS 7。
打开Docker Manager,浏览器F12看到一个报错:
chunk-vendors.49ee58fc.js:1
~tos-websocket,version: 1.1.3
app.7c238386.js:1 production
chunk-tos-components.b55e6beb.js:1 tos-components v26.6.23
app.7c238386.js:1 tos build date 2026-06-23 18:38
app.7c238386.js:1
~ redirectIfUnauthenticated ~ to, next, store, isToOtp: {name: 'desktop', meta: {…}, path: '/desktop', hash: '', query: {…}, …}
chunk-028741e0.58011e28.js:1
~ imgages ~ themeMode: light
~ initSocketBus ~ buffer_data: []
desktop.f0ef4c29.js:1
~ handleDesktopRouteQuery ~ params: {__ob__: t}
app.7c238386.js:1 [Violation]
'load' handler took 253ms
~ webTaskSocketOpen ~ "success connect task center socket"
~ openApplication ~ item: {…}
chunk.chunk-vendors.js?v=1781662489598:45 tos-components v26.5.28
app.js?v=1781662489598:1 Uncaught (in promise) {is_login: false, code: false, msg: 'lstat /home/docker/DockerData/: no such file or directory', data: {…}, time: 0.00007364, …}
isMigrateData @ app.js?v=1781662489598:1
await in isMigrateData
mounted @ app.js?v=1781662489598:1
await in mounted
Bi @ chunk.chunk-vendors.js?v=1781662489598:9
Hn @ chunk.chunk-vendors.js?v=1781662489598:9
insert @ chunk.chunk-vendors.js?v=1781662489598:9
O @ chunk.chunk-vendors.js?v=1781662489598:9
(匿名) @ chunk.chunk-vendors.js?v=1781662489598:9
An.e._update @ chunk.chunk-vendors.js?v=1781662489598:9
e.get @ chunk.chunk-vendors.js?v=1781662489598:9
Ln @ chunk.chunk-vendors.js?v=1781662489598:9
ar.$mount @ chunk.chunk-vendors.js?v=1781662489598:9
56d7 @ app.js?v=1781662489598:1
l @ app.js?v=1781662489598:1
0 @ app.js?v=1781662489598:1
(匿名) @ app.js?v=1781662489598:1
app.7c238386.js:1
~ MicroAppEventsBus ~ publish ~ type, { data, appId }: changeDialogInfo {data: {…}, appId: 'docker'}
app.7c238386.js:1
app.7c238386.js:1
await in mounted
app.7c238386.js:1
app.7c238386.js:1
F2-221 6G MAPL0304V20 TOS 7
- Eternalblue
另外,还有些小问题:
1、重启后,openclaw小龙虾虽然显示是启动状态,但是直接访问web后台是502,需要点重启网关才可以正常使用
2、tos7我发现有概率用一阵子后,加密文件夹里的东西无法复制出来,然后此时访问nas后台登录后是空白的,遇到这个情况需要物理重启nas才行,这个情况是有几率出现,暂时不知道怎么稳定复现这个bug
感谢反馈。针对您遇到的这两个问题, 以下是说明和建议:
1、OpenClaw 重启访问报错 502:这是由于 OpenClaw 服务底层的初始化和网关载入需要一定的时间。系统刚重启完成时,实际上后台服务仍在加载中,导致直接访问时出现 502 报错。建议系统重启后稍等 1~2 分钟,等待后台完全就绪后即可正常访问。
2、加密文件夹无法复制/后台空白:这通常是由于某些特定进程偶发性异常、占用系统资源过高导致的。由于是偶发问题,建议您下次遇到时先不要物理重启,直接通过以下链接联系在线技术支持协助定位问题:https://salesiq.zohopublic.com/signatur ... 97d0be8892
